Topic: Random Transition plugin stops on MultiAdditive
ChreecePRO (OEM)Member since 2014
When set videoRandomTransition: yes the next transition plugin is randomly selected until the MultiAdditive comes up.
Then it stays on this plugin and you must manually select another...
geposted Sun 16 Aug 15 @ 9:45 pm
