HI All,
Just a quickie and hopefully an easy one to resolve.
I have noticed that when I fire up a playlist from my iTunes library (showing in the menu column) that the tracks are not arranged in the same order that they are in the playlist within iTunes.
I thought a simple click on the top of the menu bar etc within the VDJ ITunes playlist would resolve to put them in a like for like order, however for some reason I can’t seem to get this to happen.
Im using the latest Pro version of VDJ 8 on Windows 10.
Any ideas?
Appreciate your help folks
DJ Simon Murray
Any ideas?
DJ Simon Murray
geposted Thu 27 Aug 15 @ 12:03 pm
Right click any of the columns at the top and select the top option "reset sort order". That should work!
geposted Thu 27 Aug 15 @ 3:27 pm
Super my friend, that worked!
Thank you so much.
Simon.
Thank you so much.
Simon.
geposted Thu 27 Aug 15 @ 5:39 pm
