Topic: Volume sliders are shaking
I have this issue all of the sudden... When the controller (pioneer sx) is connected and the left volume slider is at the maximum position starts to shake! it s only visual problem, Does not effect the sound but it's annoying
geposted Thu 03 Sep 15 @ 8:18 pm
Probably fader bleed, its a mechanical fault, nothing to do with VDJ
geposted Fri 04 Sep 15 @ 4:57 am
Thanks man... You re right!
geposted Fri 04 Sep 15 @ 2:39 pm
