I've been using VDJ for years and I've never encountered any issues with it, like ever.
Recently I upgraded my system to a Skylake system and ever since I've had nothing but issues with VDJ constantly crashing. Its seems totally random and can some times last for upto 20 minutes before crashing while other times it will do it 3 times in 5 minutes. The crashing seems to occur while I'm searching through my music folders however I'm 100% certain I've got no issues in my music files as all was working perfectly before the upgrade.
I've worked out if I set Exclusive Audio to On it takes a lot longer to crash (upto an hour sometimes) but it still crashes eventually.
I'm thinking it might be the new Nahimic Audio software included with my motherboard which is causing the issues but as of right now I'm really not 100% sure what is going on?
DXDIAG - http://pastebin.com/wcWN0b3Z
Please help.
Please help.
geposted Tue 08 Sep 15 @ 8:07 am
Your crash is video related, not audio :)
We have the reports so will take a look.
geposted Tue 08 Sep 15 @ 8:29 am
Any feedback on this issue?
Its really annoying me now, I've tried things on my end like uninstalling and reinstalling, different driver versions, even tried splitting my 4000+ MP3s up into seperate folders incase there was to many files in a single folder but its still crashing constantly.
Cheers
geposted Sun 13 Sep 15 @ 10:09 am
OK, so i think I've located the cause of the problem.
Looks like it was actually G Sync which was causing my VDJ to crash (it was set to Fullscreen and Windowed mode in Nvidia CP), disabled it about an hour ago (set it to Fullscreen only) and so far no crashing so its looking good. Will update this topic again if anything changes.
EDIT
Nevermind, lasted just over an hour then crashed twice in 3 minutes.
EDIT
geposted Sun 13 Sep 15 @ 4:13 pm
