Topic: Still crashing when playing mp3+g files
random karaoke mp3+g files are crashing both of my laptops. had no such issues several builds ago. they either crash instantly when loading or right at the end of a track. Happens on both win 7 and win 10 and on intel and nvidea video cards. it seemed to start around build 2412 and still does it in the latest build
geposted Fri 18 Sep 15 @ 2:43 am
when it crashes, it just closes... no dialogue. then it starts right buck up, instantly crashes again and after a moment starts again.
geposted Fri 18 Sep 15 @ 2:47 am
I tried a lot of my mp3+g karaoke and have not one crash.
I have a gig tonight and I will see more karaoke to play.
I have come to a habit that I re-zip all my files with the standard settings. back in the days, if the zip file was other than the standard setting, I had problems.
So now, I just use KJ-File manager to unzip and re-zip it (just a habit now).
Try doing this to see if it the problem goes away. Use KJ-FIle Manager from Lathshaw.
geposted Fri 18 Sep 15 @ 4:18 pm
Problem might occur while seeking, should be fixed in next update.
geposted Fri 18 Sep 15 @ 10:23 pm
I am having the same problem with my karaoke (mp3+g files)...it seems certain ones will make the computer crash...I never had this problem with VDJ 7
geposted Sat 19 Sep 15 @ 1:51 am
im not using zipped files.. no need for zips in the 21st century
geposted Sat 19 Sep 15 @ 1:58 am
for me it crashes when either loading the track or it'll play and with about 10 seconds left it'll crash. I'd bet it has to do with intro and outro graphics
geposted Sat 19 Sep 15 @ 2:02 am
I've been having the same issues. Random karaoke files causing the screen to do 1 of 2 things. Either it will flash the program off without warning or it will lock the screen up. Is there a solution for this??
geposted Wed 28 Oct 15 @ 8:49 pm
@thebighouse
what build of VDJ8 are you using?
geposted Wed 28 Oct 15 @ 10:19 pm
