I have and external hard drive formatted for Mac file system where i store all my music and a Macbook Pro where i run Virtual DJ 8 Pro. Whenever i start Virtual Dj with my external HD connected i add all my music stored in it to Virtual Dj's database and it works ok, it assumes the paths correctly as "/volumes/mydiskname/". But when i exit Virtual DJ and open it again the filepath to the songs changes to "D:\" so whenever i load the songs there's a file path error. How can i solve this?
P.S: Tried on Virtual DJ7 and the same thing also happens
geposted Fri 18 Sep 15 @ 10:17 am
Where exactly do you see this "D:\" ?
geposted Fri 18 Sep 15 @ 12:39 pm
I see it in the file explorer under file path column (if you have it activated to show) and in the tag editor in the file path field
![](/image/56158/170700/Captura de ecrã 2015-09-18, às 14.07.46.png)
geposted Fri 18 Sep 15 @ 1:07 pm
Maybe you should clean your database...
geposted Fri 18 Sep 15 @ 1:46 pm
it shouldn't be necessary to clean my database and re-add all of my music everytime i start Virtual DJ
geposted Fri 18 Sep 15 @ 2:19 pm
Does VirtualDJ have permission to write to the drive?
Check on the drive's VirtualDJ folder if it contains a database.xml that is not empty.
Also make sure that the drive is connected before starting virtualdj.
geposted Fri 18 Sep 15 @ 2:39 pm
Thanks Adion it's solved, i was missing the Virtual DJ folder on my drive because my user didn't have permission to read/write the drive
geposted Fri 18 Sep 15 @ 3:07 pm
