Hello. I am having a problem with my Pioneer DDJ SR and have been for some time. I am getting more accomplished with my DJ skills and love Virtual DJ on the whole. The problem I am having relates to when I press the "Slicer" button to use the Slicer feature. When I press it with a track playing, all of the lights start quickly flashing randomly and instead of having eight different options on the smart pads as far as slicer variations all of the 8 pads function in exactly the same way as the first pad does. Also the other pads remain flashing quickly and randomly even when a particular pad is pressed. Basically, 7 of the 8 pads are non-functional in addition to the light flashing issue. Can you help?
geposted Fri 18 Sep 15 @ 12:31 pm
what if you try to choose a different "Step" for the Slicer ?
If not mistaken, this should be offered with SHIFT+PRM+/- buttons
geposted Fri 18 Sep 15 @ 9:02 pm
DJDAD!!!!!!!!!!! You ROCK!!!! And I knew it was gonna be you who responded to save the day!
geposted Sat 19 Sep 15 @ 12:29 am
