Topic: Should this script work?
I don't know if this should work or not.
Virtualfolder_add 'club' & goto_last_folder & browser_scroll +1 & load & goto_pos 25% & play
Adding to vfolder and goto last folder is executing, but the rest won't.
geposted Fri 18 Sep 15 @ 6:47 pm
maybe the goto_last_folder takes some time, so the rest of the script is executed before it goes there ?
If you split the action in 2 parts, and use one button at time, does it work ?
geposted Fri 18 Sep 15 @ 8:57 pm
Go to last folder does have a lag to it, use a repeat start script to add a delay, I think ~50ms or so, I can't remember
geposted Fri 18 Sep 15 @ 9:21 pm
@djdad, yes both parts execute well if run independently.
@loco, thanks, will try that.
geposted Sat 19 Sep 15 @ 10:31 am
