For some reason, when searching certain songs on content unlimited, the dock icon shows 100% and then not only do the tracks not load when I move them up to a deck, effects, and other sounds don't work either. It's almost as if the software freezes. Not sure why this is the case.
A bit worried about using this for gigs now. I just recently purchased virtual dj after using mixxx for a while.
Using an early 2015 MBP, 8gb ram.
geposted Sat 19 Sep 15 @ 6:46 pm
