The Titler always displays the same text
geposted Mon 21 Sep 15 @ 8:41 am
There is a problem, that I just confirmed. If you use the deck version, it does get stuck at times. On the master, if you leave it on, it will change, but if you click it on, the previous title will come on first, and then the correct one will appear. hopefully it will get looked at.
geposted Wed 23 Sep 15 @ 4:13 am
Have you seen my error message ?
geposted Thu 15 Oct 15 @ 9:35 am
Missed this the first time around.
It will now indeed :)
geposted Thu 15 Oct 15 @ 1:17 pm
Fixed for the next build.
geposted Thu 15 Oct 15 @ 1:24 pm
The Titler is better now, but not yet OK
Please test as follows:
Setting: Delay = 0 s, Duration Always
Load a Titel to Player A
Load a Titel to Player B
activate the Titler
(not load a new Titel and not deactivate the titler)
then crossfader switch from Player A to Player B > Player B to player A (and so on)
then always the same text is displayed !!
activate the Titler
geposted Wed 21 Oct 15 @ 8:25 am
In that case it's not showing the title again since you just played both songs already.
(Would otherwise get a bit messy when scratching and the title is constantly switching :p )
geposted Wed 21 Oct 15 @ 9:09 am
I mean not when scratching, when i scratching the titler is off !
geposted Wed 21 Oct 15 @ 10:10 am
I'm still not sure in which situation you would be playing the same 2 songs right after each other.
geposted Wed 21 Oct 15 @ 10:21 am
