when i enter the audio setting and change the setting i press apply it freezes and then crush i use dennyo interface and 4 deck swap dunno if its in the skin or or the vdj8 bugs plz check it out plz thx
geposted Wed 23 Sep 15 @ 2:56 pm
mac version
geposted Fri 25 Sep 15 @ 1:40 pm
Does it do the same thing with other skins?
geposted Sat 26 Sep 15 @ 5:36 am
yes i noticed that
geposted Sat 26 Sep 15 @ 1:11 pm
