I recently upgraded to Windows 10, since then every once on a while my MixTrack Pro does fails to work. Lights turn on and then turn off without connecting and wanting to work with VirtualDJ 8. Also, sometimes it works just fine and sometimes it starts out working and then after about 5 minutes MixTrack Pro stops working.
I'm looking to upgrade my console but in the mean time I'm wondering if I should revert back to Windows 8. Anyone with a similar issue or with ideas?
Thanks
Thanks
geposted Mon 28 Sep 15 @ 7:10 pm
Found my own answer - here is the link for anyone else experiencing this problem http://www.virtualdj.com/forums/204227/PC_Version_Technical_Support/external_soundcard_vdj_usb_crash.html
geposted Mon 28 Sep 15 @ 7:18 pm
