Topic: Search Database problems on network
Hey i have two pc on network sharing the same hdd with the music when i add the network hdd or a network location to the search db its just work until i turn the pc off. so i need to do the same every day cause its not saving the search db change on the remote computer.
pc1---master HDD Shared with Music VDJ8-------------------------Pc2 VDJ8 music from network HDD of PC1
Can anyone help me??? Thanks
geposted Thu 08 Oct 15 @ 9:56 pm
Map the network share as a drive letter, and make sure it has write access. Then vdj should find it and store the database on the share.
geposted Fri 09 Oct 15 @ 4:22 am
