Forum: Old versions
Topic: Low Kill (for a measured time frame?)
mcs1234PRO InfinityMember since 2010
VDJ Pro7 user here ... with a very odd MIDI mapping question. I have two buttons (L+R) coded to "Eq_Kill_Low" for effect and to smooth out "heavy" mixes. Because I am sometimes stupid, I've had to add "while_pressed" at the end of it, so it will return to normal when I let go.
Does anyone know of a way to "time" this effect?
Example: "Deck 1 eq_kill_low 60000 ms" is what I would like to do, but it produces a syntax error. Idea being ... hit the button, low is killed for a minute or so, then returns to normal.
I tried the EQ reset on load (enabled) but it resets 'em all and changes settings to mid and high back to flat, which I never want to do.
Thoughts? and thanks!
Doug
geposted Wed 21 Oct 15 @ 7:41 pm
No, you can't do that with VirtualDj 7. You can do that with VirtualDj 8 though.
geposted Wed 21 Oct 15 @ 9:04 pm
Ok, thanks!
geposted Thu 22 Oct 15 @ 11:49 am
