Hi Guys,
I put this in as ticket but was redirected here...I seem to be having problem with older video files. All the new one's work correctly.
I saw that other folks were having a similar problem but possibly only one video type.
In order to demonstrate the problem, I have uploaded a video to youtube. Please go to:
https://youtu.be/3cYfKWIfQwk
It seems to be older ".mpg" files as well as "VOB" files.
.mp4's seem to be fine
Appreciate your help.
geposted Thu 22 Oct 15 @ 7:06 pm
what build are you running there was a recent fix for this maybe still beta......
also probably need to upload a sample file if its not been fixed by a recent beta
geposted Thu 22 Oct 15 @ 7:17 pm
Yes, update to the latest beta and it should be fixed.
The build you are using has this bug.
geposted Fri 23 Oct 15 @ 8:26 am
Thanks I'll try that and report back
geposted Fri 23 Oct 15 @ 5:40 pm
Did a sink test tonight for 5 hours, all seems good :) I gig a minimum of 3 nights a week, so can't take chances...thanks guys for your input @pachn and @wickedmix! Really appreciate the suggestion
geposted Sat 24 Oct 15 @ 12:10 am
Full gig tonight, system worked perfectly...thanks again guys, problem solved.
geposted Sun 25 Oct 15 @ 5:40 am
Hi there, I'm having this very same problem. I've installed latest version of VDJ but still it doesn't work. I have over 1,000 files only playing audio. can you explain to me how you fixed it please ?
geposted Sun 25 Oct 15 @ 9:36 pm
upload a sample file so it can be tested i would say
geposted Sun 25 Oct 15 @ 9:46 pm
weeshooey wrote :
Hi there, I'm having this very same problem. can you explain to me how you fixed it please ?
I installed the beta build 2522, I'm wary of beta but did it using a backup version, however it worked without any bugs at all and got my old videos back (and I also had a lot of VOB and mpg files which were affected)
geposted Mon 26 Oct 15 @ 2:43 am
