Any update on this ? I'm not using VDJ live until this is fixed. Left it running today and the same issue after about 1.5 hours.
geposted Sun 08 Nov 15 @ 4:57 pm
If you are using the Denon ASIO drivers that could be the culprit. Try using WDM (WASAPI) instead. Seems to have cured the issues on my DDJ-SX2 although I have only done one gig since changing. I used my MC6000 this weekend for two gigs with the WDM drivers and had no problem at all.
Keith
Keith
geposted Sun 08 Nov 15 @ 6:26 pm
Keith
Keith
How do you try this?
geposted Tue 24 Nov 15 @ 11:49 am
Set your sound config to select MC6000 drivers and not Asio. this is for external mode.
geposted Tue 24 Nov 15 @ 12:01 pm
what drivers are those, all my denon ones are asio and build 1072 what one is that http://www.virtualdj.com/wiki/VirtualDJv8.0builds.html
geposted Wed 25 Nov 15 @ 12:11 am
kradcliffe How do you have yours showing Denon MC6000 but not Denon asio Drivers
![](/image/78295/175263/asio.jpg)
geposted Sun 29 Nov 15 @ 5:28 pm
Those are the drivers Windows creates when the device installs on the PC.
geposted Sun 29 Nov 15 @ 5:32 pm
What when you connect the MC 6000?
Strange i don't have them then. Maybe because i installed the asio to start with?
I,m assuming you have not installed any asio drivers then from Denon
geposted Sun 29 Nov 15 @ 5:34 pm
No because they are crap!
geposted Sun 29 Nov 15 @ 5:57 pm
Never had an issue to be honest
geposted Sun 29 Nov 15 @ 6:08 pm
