Hi - is this possible?
I have a DJM 2000 nexus mixer, 2 x 2000 Nexus CDJ's & a DDJ-SX controller
Is it possible to have them all connected to VDJ at the same time?
I use a 4 deck skin by default so in my mind it should be possible just not sure how to configure it... any suggestions
Many thanks
Many thanks
geposted Tue 27 Oct 15 @ 6:54 pm
maybe this image from the DDJ-SX manual will help but it would leave out the nexus mixer not sure why you would need 2 mixers anyhow
geposted Tue 27 Oct 15 @ 8:29 pm
Yes it is possible, just specify what controller controls what decks (in the Controllers section of options).
No need to even connect the CDJ audio, unless you want it as fallback.
geposted Tue 27 Oct 15 @ 8:42 pm
Thanks Guys - your correct Wicked on the two mixer requirement - there is no need for that but I would prefer to use the Nexus mixer over the SX one for obvious reasons. I'm in the middle of building a new studio so am working on the layout / position of stuff to be able to put the cables behind the false walls. To be fair I may never actually use this set up but wanted to know if it is a option so I can put it in the plan so to speak.
Thanks again for the advice.
geposted Tue 27 Oct 15 @ 11:16 pm
Sorry to "hijack" this a little bit, but I have a gig coming up with CDJ players and DJM mixer already on location in the DJ booth. No space left to bring my own SZ controller :( I really need my VDJ laptop, because it is the only software that suits my needs.
Can I plug in the CDJ's and DJM with USB only in my laptop and have a go with VDJ? Or do I need drivers or something?
geposted Thu 05 Nov 15 @ 7:48 pm
What model mixer and cdj's?? I'll assume it's at least 800 or higher And if so then use you could use VDJ with those......
geposted Thu 05 Nov 15 @ 10:04 pm
All popular DJM and CDJs are natively mapped in VirtualDJ 8 and you wont need anything to install, other than the ASIO drivers for the unit that will be used as a sound card. In most cases, this will be the DJM mixer. So you need to know which model they have and have them pre-installed or even better have the installer with u.
You will probably need a USB hub too, since you ll be needing at least 3 USB ports for them.
geposted Thu 05 Nov 15 @ 10:41 pm
Thx guys! That are answers I hoped for.
Maybe I will install al drivers just for sure and feature use :)
geposted Fri 06 Nov 15 @ 7:45 am
for ROY
http://www.pioneerdj.com/en/support/software
here is a list of DJMs/CDJs ect ect ect driver updates
geposted Mon 09 Nov 15 @ 3:40 am
pseft wrote :
for ROY
Thanx!
I always carry a bunch of USB sticks with me, I'm going to download all drivers to an usb stick so I always have the correct drivers with me.
Now I'm going to rent a CDJ and DJM setup to try this setup with VDJ...
geposted Mon 09 Nov 15 @ 9:13 am
royvanmeel wrote :
Thanx!
pseft wrote :
for ROY
Thanx!
all good brother
geposted Mon 09 Nov 15 @ 2:10 pm
