Since the update on the 27/10/2015 The "LOAD" Loop button/key is not working, even when i have mapped it to a particular button it's still not responding. Any Answers would be hugely appreciated, Thanks
geposted Wed 28 Oct 15 @ 3:19 pm
What is the exact mapping you are using?
geposted Wed 28 Oct 15 @ 3:25 pm
Issue found and will be fixed soon.
In the meantime you will need to use a couple of custom buttons to access to your Saved Loops by specifying the slot number. E.g. for the 1st Saved Loop you need a button to save as loop_save 1 and a button to call as loop_load 1
geposted Thu 29 Oct 15 @ 5:09 am
