We are brand new to VDJ. We are using it on an Emulator Touch Screen unit with a MOTU4Pre sound card. We've had various problems but latest problem I can't seem to solve and the unit is unusable. When I turn on the unit, load a song and hit play, the track stutters in place as if the 1/32 loop button were active. The platter won't allow me to move the track. I thought perhaps it somehow got a weird cue programmed in, so I touched the wave form to advance the track and it still stutters. This happens on both decks and for every song.
geposted Fri 06 Nov 15 @ 12:04 am
This means that the selected sound interface is disconnected. Please check your sound configuration.
geposted Fri 06 Nov 15 @ 1:10 am
The Motu Sound Card suddenly decided to no longer work. This happened on both of my systems. One hasn't been turned on since the last time it was working, so I know it was nothing that was accidentally changed by an unknowing employee.
geposted Fri 06 Nov 15 @ 5:54 pm
Have you tried to use your soundcard with another application as well ? Or even to do the classic windows sound test ?
geposted Wed 11 Nov 15 @ 10:30 am
