Since Build 2522.1077 songs that I play for more then 45 seconds (default setting for historyDelay) are not marked as "Played" any more. Column "Last played" does not change.
That always used to work, no changes in settings, no changes in the skin!
First time an update breaks something really important :(
please fix that soon, or tell me how to go back to an older build
geposted Fri 06 Nov 15 @ 3:45 pm
I believe they only get marked as played if the volume fader of the deck is up. And by up I mean at least over 1/4 of its way.
geposted Fri 06 Nov 15 @ 4:02 pm
Thank you, did not know that
geposted Thu 12 Nov 15 @ 11:04 am
