Topic: DDJ-SB2 pads register as hit twice (Occasionally) - Page: 1
I have a new DDJ-SB2 and occasionally the pads play/pause and hotcue 1 (Not sure about other pads since I use those very little anyhow) register a double click. I don't think the pads double click but the song either stutters on the hotcue or the play/pause will not pause but play again with a very brief stutter (Or will pause again from play).
It usually happens after I have loaded a new track to a deck. I can't seem to repeat it after that. It happens on both decks.
Faulty controller, Windows 10 driver issue or VDJ issue? Using V8 2522b
geposted Sat 07 Nov 15 @ 6:06 pm
Are you able to tell it isn't you who is triggering the pad twice? Because they are very sensitive.
geposted Sat 07 Nov 15 @ 6:24 pm
maybe its only happens while vdj is scanning the new track?
best to wait till that's done before playing it.
also u might do a firmware update on the controller. even though its new it may have sat on a shelve for months.
geposted Sat 07 Nov 15 @ 6:26 pm
Not seeing any new FW for the SB2 yet. But yeah you might be right on the scanning. I do tend to jump the gun on tracks I load. Will test that and get back to you.
geposted Sat 07 Nov 15 @ 7:13 pm
This happens to me too. Pioneer DDJ-SX2. The pads on the Roll work when they want. Most never work. This is a new problem. Noticed on Friday for the first time. The only change it the build/version of VDJ8.
geposted Tue 10 Nov 15 @ 5:14 am
dcomoPRO InfinityMember since 2012
Are you guys running the latest firmware for the SB2/SX2 I had this problem a year ago when the SX2 was originally released, however the latest firmware fixed it for me.
Since then, I haven't seen this problem at all. (The reason why I knew it wasn't VDJ, it the double hit would occasionally appear in Serato as well.)
geposted Tue 10 Nov 15 @ 4:40 pm
ChreecePRO (OEM)Member since 2014
I have exactly the same problem since the last build i think... FW: latest (dec-14)
geposted Tue 10 Nov 15 @ 4:43 pm
My problem is since the last update as well. It's not the firmware.
geposted Wed 11 Nov 15 @ 1:48 am
Well go back to a previous build and see if the problem still exists
geposted Wed 11 Nov 15 @ 10:29 am
Are you guys using the default mapping files ?
geposted Wed 11 Nov 15 @ 12:49 pm
Yes I am using default mapping
geposted Wed 11 Nov 15 @ 1:21 pm
Me too. Haven't changed a thing. Accepted the update last week and the next time I used Virtual it's been buggy.
geposted Thu 12 Nov 15 @ 1:25 am
This is a bug-report forum.
geposted Thu 12 Nov 15 @ 1:55 am
Guys, i have sent you a mapping test file via PM.
Please check and report back.
You need to put that mapping file into the /Mappers folder and then open VirtualDJ and select it from Settings->Controllers tab (so not the factory default this time, the other one ;) )
Thanks
geposted Thu 12 Nov 15 @ 12:23 pm
The mapper works like a charm :) Thnx!
geposted Sat 14 Nov 15 @ 5:05 am
You won't know if it's a bug notably regression if you haven't tried it on earlier builds
geposted Sat 14 Nov 15 @ 12:39 pm
Thanks for the feedback.
I can see big difference here with the SB and SR here too.
Mappings for DDJ-SB, DDJ-SB2, DDJ-SR and DDJ-SX2 will have these updates in next software release.
geposted Sat 14 Nov 15 @ 1:36 pm
Is this a problem if you are using a custom mapping or is it default only?
geposted Sat 14 Nov 15 @ 2:07 pm
DJ, I've used the pads for several months. The only thing different is that I updated.
geposted Sun 15 Nov 15 @ 4:31 am
Can you tell me what you changed in the XML so I can add it to my own custom map file? Thanks.
geposted Thu 19 Nov 15 @ 3:45 pm
69%
