Need up to date mapping for Vdj 8 and denon dn mc6000.......having various issues with non functioning controls on mc 600 with the vdj mapping from denon website....the controller is not moving various functions on the softwear...done the usual things like reinstalling drivers mapping etc from denon site
im using laptop with windows 7
geposted Fri 13 Nov 15 @ 9:06 pm
It's naively supported in v8.
So simply make sure that you remove all mappers you may have added manually, and everything should work
geposted Sat 14 Nov 15 @ 6:48 am
What functions? Some functions do not move, using MC6000. Are you using Int Mix or PC mix?
geposted Wed 18 Nov 15 @ 7:13 am
