I've created a few drum sound samples as .wav files, clean, with the wave levelling to 0 at the end and start, and dragged them into VDJ8. For some reason, they "click" at the end of the sample which is actually the program playing a split second half of the beginning of the sample, for some reason. Please see this video to view the problem in more detail.
https://youtu.be/pUNUj24kLWg
geposted Sat 14 Nov 15 @ 3:33 pm
what happens if you set them as loops
or adjust the in out markers in the sample editor.
what build vdj8 is this?
also a bit curious that a home user is able to use a controller and it talking about a upcoming gig?
geposted Sat 14 Nov 15 @ 4:54 pm
WARNING to anyone who may play the above video:-
It contains strong language.
Flamin_D2, this forum (and YouTube in fact) is used by people of all ages. Please refrain from using strong language.
geposted Sat 14 Nov 15 @ 5:37 pm
Could you share one of the samples you used?
geposted Sun 15 Nov 15 @ 7:09 am
No problem with the samples here, make sure you update your vdj build to the latest version.
geposted Mon 16 Nov 15 @ 9:27 am
sound glitch in beginning of samples, when playing some drum kick samples in stutter sampler_mode.
here are some samples files
https://www.sendspace.com/file/ak2yqf
tested on osx 10.7 and win7 builds 2587 and 2582 (8.1) also tried 2522 (vdj8.0)
thank you
thank you
geposted Wed 02 Dec 15 @ 12:44 am
