invert_deck 'right' does not switch from Deck 4 to 2.
geposted Sat 14 Nov 15 @ 11:26 pm
Yes, it will be fixed on the next update
geposted Mon 16 Nov 15 @ 9:55 am
how can I workaround this issue? I know I can click on deck 2 with the mouse, but what is the script code for a keyboard shorcut
thank you
thank you
geposted Thu 19 Nov 15 @ 1:37 pm
Depends on what hardware you are using. Prior adding the invert_deck action, there were ways to invert the left/right decks (e.g. using leftdeck/rightdeck actions)
geposted Thu 19 Nov 15 @ 11:11 pm
