Hello all,
I was creating folders for songs according to the keys that virtual dj analyzed each song as. When I loaded up a track virtual dj would analyze the key and it would say "1A" for example but if I loaded the same song up on a different deck the key would change to "6A". I tried it again on the first deck and then the key changed to "11A". None of the songs were manipulated when i put the same songs on different decks, the tempo was the same I synced them. And when I did get the songs matched up I played them exactly at the same time the quality gets very glitchy, I would have assumed that if I play the same song at the same time it would sound like just one song playing but there is a lot of background noise. I am using a numark mixtrack quad. Thanks for the help!
geposted Mon 16 Nov 15 @ 4:36 pm
Does it actually change the Key of the track or is just the value that you see changing ?
Check the setting Autokey in OPTIONS . It should be on No.
geposted Mon 16 Nov 15 @ 5:48 pm
