Topic: RECORDING MULTIPLE FILES IN VDJ8 OR 8.1
IN VDJ 7.0.5 and up had this multiple recording option which was very good, is there a reason atomix has abundant it in vdj8?
is there any way we can get that back
geposted Thu 10 Dec 15 @ 8:50 am
What exactly are you missing?
If you mean the ability to split your recording into multiple files, each time you fade from one deck to the other, the feature is still there.
Settings->OPTIONS tab->Enable "Show Advanced Options"-->Search for RecordAutoSplit-->Set it to Yes
thank you djdAD very appreciated
