Topic: VDJ Remote Disable Automatic Tempo Changes?
How do I disable the feature on VDJ Remote which keeps adjusting the tempo/pitch of my songs when I use the little wand button on the screen to fade from deck a to deck b?
geposted Tue 15 Dec 15 @ 9:45 pm
I don't think that is a remote "problem".
I think you should set the fading option in the automix menu.
geposted Wed 16 Dec 15 @ 12:10 pm
Thanks, I tried changing those and they don't seem to make a difference on the remote app. When I hit the wand icon on the remote app it does shift from the playing deck to the non playing deck but it also adjusts the tempo of the track as if sync was on which I don't want. I just want to simply fade from deck A to deck B and vise versa without any speed changes to my songs.
geposted Wed 16 Dec 15 @ 2:02 pm
taylaPRO InfinityMember since 2007
Try the bottom setting: None (back to back). If you haven't already tried it.
geposted Wed 16 Dec 15 @ 2:08 pm
Ahh, cool, that's the one I haven't tried yet. I will give it a go tonight.
geposted Wed 16 Dec 15 @ 3:05 pm
geposted Wed 16 Dec 15 @ 6:18 pm
Ahh, now we're talking. That post describes exactly what I was running into!
geposted Wed 16 Dec 15 @ 9:52 pm
Odd, I loaded that skin (which is completely different than the default) and it works without the tempo changes now. I wonder how i get the default VDJ remote skin back, it seems gone for good.
geposted Thu 17 Dec 15 @ 12:20 am
geposted Tue 22 Dec 15 @ 11:04 am
