Forum: VirtualDJ Skins
Topic: is_battery not working ?
When using the Swap 4 Decks Skin I noticed that the battery symbol does not seem to work. This should indicate if the computer is running on battery or AC power. I started to experiment and found that indeed the "is_battery" verb does not seem to work. At least on my Mac.
Any ideas?
geposted Wed 23 Dec 15 @ 12:07 am
is_battery is only working on PC (Windows)
geposted Wed 23 Dec 15 @ 12:24 am
Ah, thank you! Thats a pity. So I assume this is the same for get_battery?
geposted Wed 23 Dec 15 @ 12:36 am
