anyone have any ideas?
The right deck is fine, but for some reason the left deck... you press play and it rewinds the track?
Thanks
Thanks
geposted Fri 25 Dec 15 @ 3:18 pm
i am afraid with these detail missing nobody could help
what controller?
are you using default mapping?
what controller?
geposted Fri 25 Dec 15 @ 4:29 pm
pioneer DDJ SR
using ergo mapper for this.
Thanks
Thanks
geposted Fri 25 Dec 15 @ 7:00 pm
not sure why you would use the ergo mapper to control a SR they are very different devices.
I would try the default SR mapper and see if the issue goes away .. it is natively supported in vdj7 and 8 so no reason not to
geposted Fri 25 Dec 15 @ 9:20 pm
Probably the reverse mode is enabled on the left deck.
You can try to assign the action reverse to a custom button and use that button then to disable the reverse mode.
geposted Mon 28 Dec 15 @ 12:15 pm
