How Can i Do Shortcut For-Stop All Samples like
at the ATOMIXMP3?
someone can help me with this?
at the ATOMIXMP3?
geposted Thu 09 Oct 03 @ 9:14 pm
-P.S-
and in Atomixmp3 u could play and go to the cues at the
same shortcuts can i do it on virtualDj 2?
geposted Thu 09 Oct 03 @ 9:22 pm
In VDJ when you go to a cue it starts playing :)
geposted Fri 10 Oct 03 @ 6:30 am
Just set up multiple shortcuts for the same key.
geposted Fri 10 Oct 03 @ 10:04 am
Yes you can put all sample in temporary mode on the same key.
So this key will start all samples and stop all samples in the same time.
The problem is that you will start all samples :(
You may try to add on the same key and in temporary mode too, the sample_volume=0 for each sample.
This command have to be upper than the sample command in the list. This should work.
If you don't understand what I say, I could try to write here a sample of the shortcut file later.
geposted Fri 10 Oct 03 @ 10:15 am
i think i understood u but if u can show me how 2 do it
please...
the part that i didnt understood is the part of the volume=0
where i am doing it?
ABOUT THE CUES,
on the Atomixmp3 u could press on the shortcut of some cue and it was playing the cue and not just going to the cue - i mean that in atomixmp3 was option to do shortcuts for - play cue and in VDJ there isn't option for this.
Thanks For all The Helpers !
please...
ABOUT THE CUES,
geposted Fri 10 Oct 03 @ 11:25 pm
Sorry, the right action name I tried to use is "sample_slider" but I can choose the sample number :(
I don't know how I can set this action... but I had try!
So, if someone knew how "sample_slider" works, this could help us :)
thanks
thanks
geposted Sat 11 Oct 03 @ 12:19 am
