I have a Hercules DJ Compact controller, the jogwheels are supposed to adjust pitch when shift is held down but my mapping is missing this function...
Everything else works.
My shift button looks like this.
toggle "shift" & toggle "$shift" & touchwheel "search" while_pressed
Holding shift and press REC stops recording like it should. Looks like this in the mapping.
var '$shift' ? record_cut : record
Auto mix is also activated using shift with no problems.
I've tried applying shift commands to the jogwheel with not much luck.
JOG var '$shift' ? deck 1 pitch : jogwheel
adding a hold command in there activates the deck pitch, but is active when shift is not being pressed, and deactivates when shift IS pressed.
I am out of ideas, any help is appreciated.
geposted Sat 09 Jan 16 @ 8:43 pm
aha I see the controller is supported in latest demo, seems to work.
geposted Sun 10 Jan 16 @ 10:40 am
