Im using a mac pro to play the virtual dj le software that came with the pioneer r1 but only one channel on the r1 is playing both decks A and B. (That is the crossfader on the r1 has to be on the left Channel when I'm playing deck A or B via the vdj le).
Is there/what is the fix for this?
geposted Mon 22 Feb 16 @ 9:02 am
Probably your XDJ-R1 is not set to the correct PC(software) Mixer mode
http://www.virtualdj.com/wiki/XDJ-R1.html
If that is not the case, please see http://www.virtualdj.com/wiki/Pre-listening%20with%20headphones%20with%20Sound%20cards%20without%20ASIO%20drivers.html (the Mac section)
FYI, Pioneer XDJ-R1 is offering a free upgrade to VirtualDJ 8 LE, in case you want to try it out. Simply enter your serial number (keycode) to this page http://www.virtualdj.com/le and download the installation file.
Operation Manual : http://www.virtualdj.com/documents/Pioneer%20XDJ-R1%20-%20VirtualDJ%208%20Operation%20Guide.pdf
geposted Wed 24 Feb 16 @ 3:01 am
