This problem has made working my gigs very problematic, I posted this before , but never got an answer and now can't find the post.... So here is the specifics concerning my issue.
Load tracks into AutoMix panel.
Play song as usual with preset cue points and all is good, all my keyboard settings work perfect, while everything is running on deck #1, now if I put any track on deck #2 for any reason, like hear the track or update lables on deck #2 all my keyboard settings/shortcuts stop working on deck #1...?
They will only work on deck #2 after loading a track on deck #2... even though they are specifically written for deck #1...
example deck 1 effect 'SBDJ StereoChannel' active
or deck 1 effect 'rollit' active..
This happens when AutoMix is active...
Can someone help me with this issue...
Thanks.. Joey
Thanks.. Joey
geposted Sat 05 Mar 16 @ 1:46 am
Please try using the new My Topics button here
If you posted it in someone elses thread then use the My Posts button.
geposted Sat 05 Mar 16 @ 9:17 am
