Hi all - Help required
The Mac only has 2 USB ports
Is it possible to connect the DJM-850 to Virtual DJ via USB then connect the the 2 x CDJs?
Or am I going to have to use an external USB Hub to get al 3 connected to the MAC?
I already have some issues when just connecting CDJ's vis USB - They have a mind of their own ! you assign them & then they will swap channels
geposted Mon 02 May 16 @ 1:13 pm
I have the same setup and you'll need a hub for the cdjs, just make sure its powered.
The channel swapping is as easy as going into the controllers tab and just switch them.
geposted Mon 02 May 16 @ 9:57 pm
ok i'm off to get a powered USB hub - I may be back on the assign side of the CDJ's
geposted Tue 03 May 16 @ 2:45 pm
Now have the powered hub - software can see djm850 and i can control through CDJ however I've got no sound coming through & decks don't correspond - i.e. left deck on mac screen however its loading on the right cdj850
geposted Sun 08 May 16 @ 9:21 am
Change the deck assignments in the controller mapping - page 82 of the manual....
geposted Sun 08 May 16 @ 5:30 pm
