Forum: Old versions
Topic: Virtual DJ 7.3 LE - Doesn't recognize mic
Purchased a Numark Mixtrack II that came with Virtual DJ 7.3 LE software. When I choose "config" from the main page I can see the Micsetting but says "None" and the dropdown is greyed out (the dropdowns for the speakers work fine). Using a mic plugged into the 3.5 jack on the PC and tried a USB Mic. In Windows control panel, both are recognized and I have changed the defaults several different ways.
I see a ton of information on the Pro software but not much for the LE. Hopefully the answer is not to upgrade. I would think this would be a basic function.
Thanks for your attention.
geposted Sun 08 May 16 @ 3:50 pm
