Can the Ns7iii be operated with ns7ii drivers in order to achieve performance stability......just purchased ns7iii, and running into various problems with sound quality play back as well as the play back pausing as though some one has touched the platter....some times there has been no master audio out put playing on the master.
So would it be possible to run the ns7iii on ns7ii drivers etc.....I dont intend on using the screens at all so thats not a factor for me.
need help asap to clean up the performance quality as I have a party tonight (atlantic time zone) as i write this its 4 am
if any one can provide details on what settings should be set up as in order to achieve a clean audio play back that would be great.
geposted Sat 14 May 16 @ 7:13 am
Did you ever get this issue resolved?
I am intermittently getting the same issue, as if someone touched the platter.
geposted Fri 21 Oct 16 @ 7:15 pm
Mine runs great. You may want to separate your USB cables. I have heard that combining the screen with the controller is a bit of a heavy USB load. I have used mine with the screens and board separated. No USB hubs either. If possible, plug them into separate USB busses. Many USB ports are on the same buss so there sometimes can be no real benefit to separating.
Next I would try increasing your latency here
geposted Sun 23 Oct 16 @ 11:24 pm
Thanks for the info DHoude.
Had the problem on Thursday and then at my last 3 gigs, no problem at all. If it returns, I will try the latency setting first and then separating the USBs as you suggested. I happen to know that the left and right side of my laptop have separate internal hubs, so easy enough to do.
geposted Tue 25 Oct 16 @ 4:18 am
The latency is going to make the controller have more of a delay for scratching and all. I would separate the screens before the latency. Your choice, but I see raising the latency as more of a band-aid than a goto fix.
geposted Thu 27 Oct 16 @ 4:19 pm
I have the ns7iii also. What is the best setting for latency ? I don't understand latency can someone explain in as basic term as possible thanks
geposted Fri 09 Dec 16 @ 10:45 pm
