Topic: Mapper
My keyboard mapper work some time and my controller mapper also (browsed_file_color "Red" or green,red ) Shift+ color and Show_splitpanel 'side view' off the controller
geposted Mon 13 Jun 16 @ 1:06 am
browsed_file_color 'ColorName' works fine here.
As for the 2nd action, it should be Sideview not side view., so ...
show_splitpanel 'sideview'
And Don't save the Color also...
Im sorry when you close VDJ then open it back up the color is not save.
And Cue's points also don't save when you close and reopen I was thinking it was me last night when I was making a mix for a Promoter for a gig
Check your settings for the "readOnly" setting. If it's set to yes change it to no and restart VirtualDj
