I have been able to replicate a VDJ 8.2 crash by renaming a playlist and save over it. See video clip
https://youtu.be/Crb0nChINWw
geposted Tue 14 Jun 16 @ 7:07 pm
I always save a playlist as a new name then delete the original one. Had all sorts of issues with this in the past.
geposted Tue 14 Jun 16 @ 7:09 pm
what version are you using ?
geposted Tue 14 Jun 16 @ 7:50 pm
8.2
geposted Tue 14 Jun 16 @ 8:30 pm
ProfLee wrote :
8.2 and it does the same thing with the default skin so it's not a skin thingy.
geposted Tue 14 Jun 16 @ 8:31 pm
It crashed for me also. Same scenario as ProfLee. When saving playlist VDJ closes and re-opens, Using VDJ8.2 latest build b.3236. Default skin and V8 by FRUiT skin. Running OS X El Capitan v10.11.5
geposted Tue 14 Jun 16 @ 9:12 pm
It's only happening when using a shortcut to save?
Tried using the automix options -> save... option on both windows and pc but no crash.
geposted Wed 15 Jun 16 @ 7:04 am
