geposted Tue 14 Jun 16 @ 10:33 pm
It reads "some devices on this machine behave bad and will probably cause drop-outs in real time audio and/or video streams. To isolate the misbehaving driver use Device Manager and disable/re-enable various devices one at a time. Try network and W-Lan Adapters, modems, internal sound devices, USB Host controllers, etc."
geposted Tue 14 Jun 16 @ 10:37 pm
From your picture I don't see anything that justifies your worries. You don't have yellow or red spikes. Generally your system seems to be good to go for low latency (for dj-ing purpose) I believe you should be able to achieve latency somewhere between 2ms and 5ms which is more than enough for Dj-ing.
Unless you see red spikes there's no need to worry about DPC
geposted Wed 15 Jun 16 @ 6:29 am
