Hello everyone
I've enjoyed VDJ from when I first used it about 4 years ago with a mouse, luckily I picked up a controller and my life changed! I enjoy the colour waveform's thoroughly and I have recently moved VDJ 8.1 and all my music to a new Mac laptop(previously a much older Mac laptop). Fresh start, im using the orangejuice skin(most recent version) and I notice when loading my track, that it loads a small waveform. With the waveform options via the orangejuice skin I select a large waveform view the window increases but the waveform stays the same skinny size. It is very flat with minimal peaks and troughs. Occasionally while a track is loading the large waveform shows but once the track is loaded and analysed the waveform returns to a very small view(waveform window remains same size). Would appreciate any help that anyone can offer.... Thank you
geposted Tue 28 Jun 16 @ 6:51 am
I would suggest to give DJnice o) a PM:
https://virtualdj.com/user/djnice__o)/index.html
or to post this problem here:
https://virtualdj.com/forums/197537/addons/OrangeJuice.html?page=1
geposted Tue 28 Jun 16 @ 10:48 am
I use this.....its bigger and has more options to suit your tastes...... look for Controller by DennYo.
geposted Thu 14 Jul 16 @ 3:45 pm
The waveform hight is affected by the gain value.
Since you wrote this:
I assume it is your gain that is set too low.
geposted Mon 18 Jul 16 @ 10:17 am
