Forum: Old versions
Topic: How do you get Higher Res Skins?
TegmarkHome userMember since 2013
The highest is only 1920x1080 on the Free version I have & would like run VDJ at 2560x1600. So is this res only with the Pro version or something?
Thanks
geposted Thu 07 Jul 16 @ 8:19 am
Pretty much all skins are native 1920x1080 as that was the way version 8 was designed.
I'm not aware of any that have a higher resolution without stretching. My screen is 3200x1800 and I just downscale it to HD.
You have posted in the V7 forum so which version are you actually using?
geposted Thu 07 Jul 16 @ 8:40 am
Hi Kradcliffe.
I have VDJ 7 Free. Wish it would go to 2560x1600. Upscaling looks a little blurry.
geposted Thu 07 Jul 16 @ 8:47 am
geposted Thu 07 Jul 16 @ 8:58 am
I would recommend to try VDJ 8 then.
Graphics are still upscaled and may not look as sharp as possible, but text, cover art, waveforms, ... are properly rendered at whatever resolution you have, so will still look sharp.
geposted Mon 11 Jul 16 @ 11:40 am
