I want to go about redownloading VDJ8 but Im afraid that I will lose all of my cue points. How do I save or back up my cue points ?
geposted Wed 13 Jul 16 @ 4:55 pm
Redownloading? What happened to your (implied) first download? After downloading something, it's good practice to keep it and also back it up.
The cue points are stored in the database, so simply keep a copy of that (see above. backups are important).
Reinstalling should not delete the existing data anyway - unless you've uninstalled your previous version and already deleted your database.
geposted Wed 13 Jul 16 @ 5:01 pm
As above Hotcues and other Track's info are stored in the VirtualDJ Database(s)
Please read further detals here http://www.virtualdj.com/wiki/VirtualDJ8_Backup%20Database_.html
geposted Wed 13 Jul 16 @ 11:00 pm
So how do I download the database if I reinstall the software ?
geposted Thu 14 Jul 16 @ 2:46 am
Did you actually read the page, it explains everything.
database.xml file rename it, reinstall v8, and then un rename it
geposted Thu 14 Jul 16 @ 2:59 am
hello everybody
DB FAILED
how i can made the DB backup, why DB is saved in external drive and not in main drive.
THANKS
GIULIANO
DB FAILED
THANKS
GIULIANO
geposted Thu 15 Jun 17 @ 10:03 am
ramelgi0 wrote :
hello everybody
DB FAILED
THANKS
GIULIANO
DB FAILED
THANKS
GIULIANO
The DB (database.xml) is placed both on the external drive for the external files, and on the local drive in documents\virtual dj
You need to backup both when doing backup, and restore the one that has been corrupted if it fails
geposted Thu 15 Jun 17 @ 10:06 am
Are the individual cue points in each track still shifted by a few frames when they are transferred from V7 to V8?
If so, what would be a quick and/or easy way to correct the cue point shift for a few thousand tracks?
Thanks in advance.
Thanks in advance.
geposted Thu 15 Jun 17 @ 7:23 pm
Yes, that shift was due to a bug in VirtualDj 7
On VirtualDj 8 there's an action "shift_all_cues" which you can use to fix all the cue points for each track that has them shifted.
As you can understand this action can be used to fix all the cues on a single track at once, not on your entire database since the offset is different depending on the track itself.
geposted Thu 15 Jun 17 @ 7:30 pm
Thanks Phantom.
Is the action "shift_all_cues" permanent, or is it a required command each and every time the track loads?
Where is the best place to put this command to work automatically when each individual track loads?
Thanks again.
Thanks again.
geposted Thu 15 Jun 17 @ 10:09 pm
once you move them they stay till you move them again.
geposted Thu 15 Jun 17 @ 10:56 pm
The cue_adjust requirement between V7 and V8 can't be too permanent if it requires an adjustment action every time a track loads.
Anyway, where should the cue adjust action command be placed, in a POI or written into the XML?
(Sorry Rlallen I did not mean to hijack your post)...
geposted Thu 15 Jun 17 @ 11:47 pm
