how do I Delete a sound effect help help it is crashing VDJ 8.2
![](/image/48059/202125/Screen Shot 2016-08-10 at 8.10.08 PM.png)
geposted Thu 11 Aug 16 @ 12:13 am
In the Virtual dj folder, in your documents folder, delete the file
geposted Thu 11 Aug 16 @ 12:32 am
it won't
geposted Thu 11 Aug 16 @ 1:00 am
it is not there
geposted Thu 11 Aug 16 @ 1:01 am
but it still shows up in VDJ
is it a vst effect?
geposted Thu 11 Aug 16 @ 1:04 am
or is it an audio file?
geposted Thu 11 Aug 16 @ 1:05 am
![](/image/92577/202131/Screen Shot 2016-08-10 at 8.10.08 PM.png)
geposted Thu 11 Aug 16 @ 1:06 am
i think it has something to do with the new build do you know how to go back a build i downloaded it but it is still on the 8.2.3343
geposted Thu 11 Aug 16 @ 1:08 am
window or mac
geposted Thu 11 Aug 16 @ 1:10 am
it is a audio file from the old VDJ 7 it says Barbara Streisand
mac
Can't you just right click (two fingers or ctrl+click) and File Operations > Delete?
geposted Thu 11 Aug 16 @ 1:21 am
well i nothing about macs...windows i would right click and go to file location or some type of search
i tried that it will not i even shut down and reload just to make sure
geposted Thu 11 Aug 16 @ 1:31 am
can you help me go back a build had no problems there i am on 8.2.3343 need to go back to 8.2.3311 i downloaded it but it still says i am on 8.2.3343
geposted Thu 11 Aug 16 @ 1:33 am
Please Please i have a gig in the AM and i am worried it will crash
geposted Thu 11 Aug 16 @ 1:35 am
did i lose you guys
geposted Thu 11 Aug 16 @ 1:46 am
geposted Thu 11 Aug 16 @ 2:06 am
i did that it is still on 8.2.3343 do i need to do something else or do i have to delete the old one
geposted Thu 11 Aug 16 @ 2:08 am
