Three times in the past 3 days I've loaded a song and the software closes and reopens. No other changes to my laptop Windows 8. Fortunately it resumes playing music.
geposted Wed 31 Aug 16 @ 11:10 pm
If your online then a crash report has been sent to the dev team.
geposted Thu 01 Sep 16 @ 12:20 am
Yes. Thank you.
geposted Thu 01 Sep 16 @ 1:30 am
It just stopped working again.
geposted Thu 01 Sep 16 @ 3:42 am
Is it happening on loading a specific song?
geposted Thu 01 Sep 16 @ 5:17 am
I have just experienced this problem. I was playing a song on deck 1 and then I loaded a song onto deck 2. The waveform for the second song didn't load and then after a couple of seconds the music stopped and VDJ closed down. After a short pause it opened up again. I've not had this happen before and I am also using b3386.
geposted Thu 01 Sep 16 @ 9:04 am
I'm on the same version running Windows 10 and have also recently experienced this exact issue. Just logged a ticket with tech support. Does anybody have any clues. I have never experienced this issue before.
geposted Thu 01 Sep 16 @ 9:46 am
Same thing happened again. It's now happening regularly. I read if I'm online an error log is sent to VDJ tech support, is this correct?
geposted Thu 01 Sep 16 @ 9:49 am
Yes this is correct so hopefully the support guys will have the error log and rectify the problem.
geposted Thu 01 Sep 16 @ 10:03 am
geposted Thu 01 Sep 16 @ 10:13 am
No specific song. Not even specific deck? But it's a real issue.
geposted Thu 01 Sep 16 @ 10:24 am
Please try if it's still happening on 3390
geposted Thu 01 Sep 16 @ 11:52 am
Same issue after updating to 3390
geposted Fri 02 Sep 16 @ 8:59 pm
Just had the same thing happen AGAIN - now on version 3398. This is becoming a worry.
Is there anyway to go back (as in a restore point)? If so, what is the most stable version of VDJ 8.2?
geposted Tue 06 Sep 16 @ 10:09 am
I post this every other day but again (since Atomix won't put up a direct link)
http://www.virtualdj.com/download/build.html
Build 3343 is the last "non-beta" version.
There should be an option to download previous builds on this tab:
geposted Tue 06 Sep 16 @ 10:20 am
Thank you very much - that's a great help. Do I simply reinstall over the top of my current version?
Or reinstall and restore my settings.xml and reload my data file?
Thanks again
Thanks again
geposted Tue 06 Sep 16 @ 10:30 am
Just install over the top.
geposted Tue 06 Sep 16 @ 10:32 am
Cheers, appreciate your time!
geposted Tue 06 Sep 16 @ 10:48 am
It hasn't happened to me since last week. Thank you guys.
geposted Thu 08 Sep 16 @ 1:18 am
I am having the same problem.so what is the best version to use to stop this problem
![](/image/54902/205813/2016-09-11.png)
geposted Sun 11 Sep 16 @ 8:30 am
