Topic: Optimizer Error 5?
When I run the VDJ Optimizer before my gigs, I get ERROR 5 on almost it's trying to optimize. Can anyone shed some light on the ERROR 5 message? Here are a few specs on my laptop
geposted Sat 29 Oct 16 @ 3:57 pm
Do you have any need to run this in the first place?
What problems do you have if you don't run it?
geposted Sat 29 Oct 16 @ 4:34 pm
I run the optimizer becuase my CPU is extremely high when running VDJ, it always has been so I trying to keep that low to avoid any freezes or shutdowns
geposted Sat 29 Oct 16 @ 8:00 pm
The optimizer just disables some services and kills some apps.
Must be something on your end.
If you want to track it down, rightclick and edit the file. Delete one line by one until you don't get an error. That way you'll fund what service/ app is causing the error
geposted Sat 29 Oct 16 @ 8:39 pm
Keep in mind that the CPU meter and the % value you see when hovering CPU on VirtualDJ skin, indicates the total amount of cpu usage, coming from all running applications
Best is to open Windows Task Manager and see how much Cpu does VirtualDJ uses and probably see if the "high" cpu comes from VirtualDJ or not.
geposted Sun 30 Oct 16 @ 1:22 pm
