i need to decide, but i don't know which one to get yet
geposted Fri 04 Nov 16 @ 5:08 am
How much money you got??
geposted Fri 04 Nov 16 @ 4:16 pm
If you use Windows get an Android, If you use Mac get an Ipad.
Communication between units will be better I think.
geposted Fri 04 Nov 16 @ 10:17 pm
i use windows but my back up is a MBP which i dont bring with me lol....
and im only going for a 2nd hand tablet, iv been thinking, if i get an android with a o/s version 4 , would that be ok or woyld i need an latest version o/s
geposted Sun 06 Nov 16 @ 4:54 pm
Instead of using the vdj remote have you considered just getting a touch screen monitor and using a two window skin?
geposted Sun 06 Nov 16 @ 6:28 pm
interesting, will look at it after friday. going away for work.
so get a touch screen and connect it to the lappy and have multiple screens?
geposted Mon 07 Nov 16 @ 12:12 pm
500$ AUD -/+
geposted Mon 07 Nov 16 @ 12:18 pm
Pretty much, it does depend on the skin having external windows,
Which will probably mean customising something yourself.
The down side is it won't be a remote, you'll be tied by a power cable but you'll get better latency.
Just something to consider
geposted Mon 07 Nov 16 @ 12:32 pm
cheers loco
geposted Mon 07 Nov 16 @ 6:58 pm
Hi I got an Android RCA tablet an I'm trying to install v8into it but no luck so far but I have to get windows to install I have seen on YouTube others didn't have Windows an it works just fine I need help please.
geposted Mon 07 Nov 16 @ 7:24 pm
You can't install VDJ8 on a tablet, lol!
You can download the remote app but that about it.
geposted Mon 07 Nov 16 @ 9:06 pm
The full version of Virtual DJ, and the Virtual DJ Remote, are two different things. As stated, the Remote works on an Android Tablet, to control the full version that is on the computer.
geposted Tue 08 Nov 16 @ 6:08 pm
