Virtual DJ now its working very good but on effects its boring the same ones, we need more fresh audio effects like the other dj softwares
geposted Sat 05 Nov 16 @ 6:14 am
Install some VST effects. There are thousands available.
geposted Sat 05 Nov 16 @ 8:59 am
How can i do that ?
geposted Sat 05 Nov 16 @ 2:14 pm
find x86 vsts,
install,
move the .dll to plugins>sound effects
profit.
install,
profit.
geposted Sat 05 Nov 16 @ 3:15 pm
Does anybody have any idea how to map a sound effect to a controller button?
geposted Sat 05 Nov 16 @ 8:04 pm
Yes but please create your own thread and I'll reply.
geposted Sat 05 Nov 16 @ 8:39 pm
While they may appear the same some are improved. The filter was unusable previously, it sounded that bad. As for the rest of it, there are only a limited amount of effects, in all instances, the rest is simply a combination of those few effects and how you implement them.
geposted Sun 06 Nov 16 @ 4:52 am
salve ho un piccolo problema con il dj virtual e da diversi giorni che dopo aver caricato il brano sulla stringa parte cn 10 secondi di ritardo e anche la mia voce dal mic esce anche in ritardo ho impostato il dj a 320 kb prima andava benissimo ma da quando la fast web a messo la connessione a 50 mb adesso si blocca sempre mi sapete dare una risposta cosa fare
Please try our German forum here.
geposted Sun 06 Nov 16 @ 11:31 am
Especially the echo effect....
geposted Sun 06 Nov 16 @ 2:12 pm
Totally agree about echo, the initial v8 version was good, once trailing was added it became great, now that it's postfader I think it's the best echo effect of any of the big 3 dj softwares.
Just after opinion here, what serato/traktor fx are most wanted? I can study traktor effects to try figure out how to replicate.
geposted Sun 06 Nov 16 @ 3:15 pm
i have mac no windows
geposted Sun 06 Nov 16 @ 11:27 pm
The filter effect is very similiar to that on the DJM900 once you change it to high resonance (in settings).
The echo effect is much better than that on the DJM900, easier to execute an echo out and far more options available. It'd be great if the echo could be linked to the pitch fader, so in the event of an echo out, one can adjust the pitch to change the speed of the delay in real time, I'm not sure if this would be possible.
The noise effect in VDJ still needs some work to be as effective as Pioneers version.
Generally I'd like to see more investment in making high quality FX, and some fun and creative ones thrown in.
geposted Mon 07 Nov 16 @ 4:35 am
pioneer skin,efeck,dj name player radio rizky umami
geposted Mon 07 Nov 16 @ 4:42 am
agree.
geposted Mon 07 Nov 16 @ 2:10 pm
I feel the echo should sound like the loop out effect when in the trails......its more of a delay effect right now...
geposted Tue 08 Nov 16 @ 10:23 pm
kenyilm wrote :
How can i do that ?
https://www.youtube.com/watch?v=aRdMBQ2gy3c
Thank you, DJ Roubo
geposted Wed 09 Nov 16 @ 3:09 pm
Glad I could be of service!
geposted Fri 11 Nov 16 @ 12:27 am
I would like to have the transpose stretch (you created a similar the brakestart/loop) and the peakfilter from traktor please,thank you
geposted Tue 15 Nov 16 @ 11:56 am
