Im using an AA 14MXR with vinyl timecode. After updating i got multiple program crashes . Opened a ticket and was told :
Welcome to Atomix VirtualDJ Ticket Support Center. Delete (or move to another folder) SETTINGS.XML from Documents\VirtualDJ. Run VirtualDJ 8.2 and test again.
That didnt fix anything. restored pc and seemed to fix the issue (somewhat) now Im afraid to update anymore. I also have problems with the program cutting the music off and literally playing the music BACKWARDS during a show.
Computer is used for djing only
geposted Tue 29 Nov 16 @ 1:04 am
The crash you experienced was specific to build 3493 and has been fixed in 3523, so it is advised to update.
Btw, are you using a windows 7 which had not been updated with Service Pack 1 by any chance?
geposted Tue 29 Nov 16 @ 5:25 am
I am using windows 7 but not sure on the svc pack. I am ready to buy a laptop and debating on a macbook pro or something with a windows OS . Advise please
geposted Tue 29 Nov 16 @ 6:03 pm
Adion... Should I be using Windows 7 with the svc pack 1 update?
geposted Sat 03 Dec 16 @ 10:10 pm
hello
geposted Sat 03 Dec 16 @ 10:31 pm
Yes, it's always recommended to keep your os updated.
geposted Sun 04 Dec 16 @ 5:20 am
