This has downloaded for install but neither the website or the install changelog have any info.
Only thing I can see so far is that Netsearch appears to have been completely removed apart from one setting.
geposted Tue 10 Jan 17 @ 6:45 pm
B3523
B3568
B3568
geposted Tue 10 Jan 17 @ 7:07 pm
seems to be sorted now
VDJ:-Denon MC7000 supported
-browser_scroll 'top' and 'bottom' can be queried
-Improve stream selection when file has multiple audio streams
-pitchResetSpeed option added
-fix docking of effects in skins with multiple browsers
-Fix pad_button_color
-Small slideshow fix (one image not shown after finished trough list)
-when forward-spin is enabled, song resumes when normal speed is reached instead of waiting for complete stop
-fix crash when 'settings' action is used with incorrect parameter
-Fix some pad action crashes
-group by filter folder no longer shows results marked hidden from search db
-xdj 1000 browser improvements
-pioneer djm-s9 support
-Fix echo crash when using DubLoop pad page with controller connected
-Rotated video support in decks and slideshow
-Fix video recording audio sync issue when input samplerate different from record samplerate
-Fix track edits with track cover
-Fade from video to image and image to video in slideshow
-Fix crash in saving mp4 tag on big files
-Skin init actions executed after skin completely loaded
-Improve mouse/touch backspins
geposted Tue 10 Jan 17 @ 8:02 pm
So what about removal of Netsearch, surely that sould be there too if it is actually a change to the executable (or did they just hope no-one would notice)?
geposted Tue 10 Jan 17 @ 8:16 pm
NetSearch being removed is not new in 3568 and we already made an official comment here:
https://www.virtualdj.com/forums/213457/General_Discussion/ContentUnlimited_-_official_comment.html?page=1
geposted Tue 10 Jan 17 @ 8:49 pm
I don't think it actually says in that statement that Netsearch is permanently removed. As you are probably aware there are users hanging on to an older build as the feature is still there.
I take it that since this build has physically removed the Netsearch settings that means it is definitely not coming back then.
geposted Tue 10 Jan 17 @ 9:04 pm
