Topic: Build 3568 unable to read controller mapping
SerinePRO InfinityMember since 2013
Hi there, I just updated to the new build and my software is unable to read my normal controller mapping, it just shows completely blank.
I have replaced the file with a backup and when I look at the file in the appropriate folder I can see the XML is not blank, but VDJ still can't read it.
Just prior to this happening I had tried using the new browser scroll trick from this thread which I changed without the controller connected, then connected it, it didn't work so I restarted VDJ, then update the software (and realised I needed to update to get it to work). When I came to look at the mapping, it was blank.
Any suggestions?
geposted Wed 11 Jan 17 @ 11:25 am
Did you edit and save your XML with WordPad?
It could corrupt the encoding. Better use Notepad (or Notepad++) to edit the XML.
geposted Wed 11 Jan 17 @ 2:38 pm
No, I just used wordpad (default XML reader on my PC apparently) to show that the document isn't blank. I do all my editing in VDJ itself
geposted Wed 11 Jan 17 @ 2:49 pm
Can you share the xml?
geposted Wed 11 Jan 17 @ 3:01 pm
I just found a second version of the file while searching for the correct one to upload. It was in a different folder. I overwrote that and VDJ is now reading those settings fine, I only lost a minor change i made since the backup.
Not sure what caused it to be wiped and I don't think I could replicate it easy so please consider this closed.
geposted Wed 11 Jan 17 @ 6:56 pm
